Hi,
I'm experiencing the same problem with the binary input 6241 after update to 2.3.0. I use the binary input with my heating system to inform BJ system when it is in regular mode or cooling mode. This worked perfectly before the update to 2.3.0. Now it works reversed. So my BJ system thinks that the heating system is always in cooking mode and when the heating system starts cooling the BJ system thinks it is in regular mode. Reconfiguring the BJ heating actors and binary input didn't have any effect. Also the configuration at the binary input between Nclose and Nopen has no effect. I understand there is a new version 3.3.0 available that should solve this reversed indication of the binary input 6241. How can I get hold of this new firmware release for the 6241?
Thanks in advance for the support.
